Activity Forums VEGAS Pro Animate Pinch/Punch Video FX
  • Animate Pinch/Punch Video FX
    Posted by Thomas Ames on August 20, 2016 at 6:11 pm
    I’m using Vegas Pro 13 and trying to use the Pinch/Punch Video FX.
    I’m using Medium Punch as my maximum “pulse”, which is at “Amount: 0.500”
    To try to ease into the 0.500 value, I have the four frames before the max set at 0.100, 0.200, 0.300, 0.400. Then, I let the max pulse hold for 6 frames before backing off in reverse order.
    It looks better than the 0 to 0.500 did, but it still looks a little rough.
    Here are images showing my timeline and some Effect Windows: https://imgur.com/a/pc4Fs
    Here’s a link to a video sample.
    Is there a way I can have Vegas automatically animate that effect to make it smoother?
    View post on imgur.com
    Thomas Ames replied 10 years ago 2 Members · 6 Replies
  • László Kovács
    August 20, 2016 at 6:27 pm
    Did you try to right click a keyframe and set it to “smooth”?
  • Thomas Ames
    August 20, 2016 at 6:47 pm
    I’m not exactly sure what you mean by selecting a keyframe.
    I see that I can set keyframes in the Pan/Crop tab of the Video Event FX window, but I only see that applying to a “zoom” effect.
    I’m also not sure what you mean by “set it to ‘smooth'”. Could you elaborate?
    Thank you!
  • László Kovács
    August 20, 2016 at 6:49 pm
    Sure, later. Right now I’m far away from my computer, I’ll try to help better when I get back 😉
  • László Kovács
    August 20, 2016 at 8:46 pm
    So here I am 😉
    Apply Punch FX to your clip (event).
    Then when you open FX properties, click on the animate button on bottom left:
    Then you’ll see a timeline, here you can add/remove/move/modify keyframes.
    When you right-click a keyfram, you can change the interpolation method between them.
    I guess you are looking for the “smooth”, but you can try the others too.
    By default the interpolation is linear.
    I hope I could help
    Kind regards
  • László Kovács
    August 20, 2016 at 8:59 pm
    Oh, I forgot to mention, that instead of an event, you can apply the FX to the track itself.
    Animating works similar in this case…
  • Thomas Ames
    August 20, 2016 at 9:49 pm
    Thank you very much!
    I missed that “Animate” button.
