Activity › Forums › Adobe After Effects › Animate path points seperately
  • Kevin Camp
    June 30, 2010 at 2:40 pm
    there is a script that will allow you to connect mask vertices to a point property (like position of another layer, or a point expression control).
    you could then create the position animation of a layer (probably a null) or of a point expression control, then use the script to have a vertex do the same animation.
    what the script will do i create keyframed movement every frame that follows the movement of the point property. if you modify the point property, you’ll need to run the script again….
    you can get the script here:
    https://www.crgreen.com/aescripts/
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
