Activity Forums Adobe After Effects Animate Objects Along A Path Dynamically?
  • Animate Objects Along A Path Dynamically?
    Posted by Lillian Young on April 24, 2019 at 3:39 pm
    I have images (pre-comped) rotating in a 3D carousel-style circle. I need to add another image now. How can I do this dynamically so that I don’t have to make manual adjustments?
    If it requires a script from AE Scripts, I’ll buy it. But I just want to know the process.
    Lillian Young replied 7 years, 4 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    April 24, 2019 at 3:49 pm
    Not that I have watched this, but seems likely the answer is contained herein.
    https://vimeo.com/63568667
    Senior Graphic Designer
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Lillian Young
    April 24, 2019 at 5:11 pm
    Thanks for responding so fast, Kalleheikki. I will check that out to see if it works for me. If nothing else, it’s a way to go about it based on his sample.
