Activity Forums Adobe After Effects Animate object along animated path
  • Animate object along animated path
    Posted by Robin Munshaw on October 12, 2019 at 12:33 am
    Hi there,
    I’ve created a path that has vertices animated to follow an underlying map. The map is a slow zoom in on Google Earth looking at the ground at about 45 degrees, so each vertex of the path is keyframed to follow a point on the map to allow for perspective shift during the zoom. This path will be an animated route on the map.
    I’m now trying to make a glowing dot follow the path as it’s revealed – is there a way to make an object follow a path that is itself animated with keyframes? The only tutorials I’ve found show how to paste a static path into an object’s position attribute, then animate the object along that fixed path, but this method doesn’t allow for a path with animated vertices.
    Thanks for any help!
    Andrew Jehan replied 4 years, 5 months ago 3 Members · 5 Replies
  • Dan Ebberts
    October 12, 2019 at 6:55 am
    Assuming that you’re using Trim Paths to set the end point of your path, an expression like this (for the position of your dot) should track an animated path:
    L = thisComp.layer(“Shape Layer 1”);
    path = L.content(“Shape 1”).content(“Path 1”).path;
    pct = L.content(“Shape 1”).content(“Trim Paths 1”).end;
    L.toWorld(path.pointOnPath(pct/100,time))
    Dan
  • Robin Munshaw
    October 13, 2019 at 5:59 pm
    Ah this worked perfectly, thank you so much!
  • Andrew Jehan
    March 15, 2022 at 7:13 pm
    I’m getting a “syntax error” on line 1 (see screenshot). Can you help?
  • Dan Ebberts
    March 15, 2022 at 7:19 pm
    You probably just need to swap out the curly quotes for straight quotes:
    L = thisComp.layer("Shape Layer 1");
    path = L.content("Shape 1").content("Path 1").path;
    pct = L.content("Shape 1").content("Trim Paths 1").end;
  • Andrew Jehan
    March 15, 2022 at 7:43 pm
    That fixed it! Thanks!
