Activity Forums Adobe After Effects Animate letters to blow/drift into position
  • Animate letters to blow/drift into position
    Posted by Jason Fisher on April 20, 2009 at 10:02 pm
    I’m looking for a tutorial or reference how to animate text to drift into place, bit like leaves falling to the ground shot from above. There should be some 3D effect but not too much – some spin on the letters on all axes.
    Using AE CS3, and I have Particular available.
    David Bogie replied 17 years, 5 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    April 21, 2009 at 12:44 am
    I’m pretty sure that there’s a Text Animation Preset that does something like this. Take a look into the Organic or Miscellaneous categories. It’ll give you a good headstart and then some tweaking to ocmplete it.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • David Bogie
    April 21, 2009 at 7:39 pm
    [Roland R. Kahlenberg] “It’ll give you a good headstart “
    Yar. You will want to have all of the Text Animation resources in front of you as you try to figure out how to apply animators and adjust their numerous settings. These are is not particularly difficult but they are less than readily apparent. Have the manual open, the online help system open, and the AE Community Help up on the Web.
    bogiesan
  • Jason Fisher
    April 21, 2009 at 7:46 pm
    Thanks guys. The 3D flutter in preset with some tweaks is good start.
  • David Bogie
    April 21, 2009 at 10:26 pm
    Chris Meyer explains AE’s text animators.
    This is fabulous for its basic clarity:
    https://provideocoalition.com/index.php/cmg_keyframes/story/after_effects_apprentice_video_tutorial_4/
    bogiesan
