Activity Forums Adobe After Effects Expressions Animate from zero to slider value
  • Animate from zero to slider value
    Posted by Rob Jennings on July 1, 2019 at 7:45 pm
    Hi everyone,
    Is is possible to add a layer expression to keyframe from a given value to another value dictated by a slider control over time t?
    For example, I would like to create a radial wipe using an expression that starts at 0% completion (value 1) at time 1, then animates to an endpoint controlled by a slider (value 2) at time 2. Is there any such expression?
    Andrei Popa replied 7 years, 2 months ago 2 Members · 1 Reply
  • Andrei Popa
    July 1, 2019 at 9:31 pm
    linear(time,t1,t2,value1,value2)
    t1 – initial time
    t2 – final time
    value1 – initial value
    value2 – final value
    Instead of writing value2 you should pick-whip your slider.
    Andrei
    My Envato portfolio.
