Activity › Forums › Adobe After Effects › Animate Coin Stack
  • Animate Coin Stack
    Posted by Christian Kruse on December 2, 2016 at 5:45 pm
    Hey everyone,
    I’m actually working on an animation where at some point a coin stack should be build up an down several times.
    I’ve got a simple 2D graphic of a coin which I want to “duplicate” and put a little bit higher and a few pixel to each side by random or vice versa “delete” the most top coin. The coins don’t need to fly or
    Of course I could manually insert 20-30 coins and animate each one itself (i.e. Transparency) but this would be pretty cumbersome. So I wonder if there is any other possibility to do this.
    I’ve got AE CC2017 and the only extra PlugIn I’ve got is the Trapcode Suite.
    Kind regards
    Daniel Waldron replied 9 years, 9 months ago 2 Members · 3 Replies
  • Christian Kruse
    December 2, 2016 at 8:32 pm
    Kinda solved my problem.
    I inserted a Slider Control into a Null-Object in my main comp.
    Made a new comp with 25 coins and arranged them. Afterwards I used this expression on the transparency:
    n = thisComp.numLayers;
    if (comp("mainComp").layer("theNullObjectsName").effect("theSliderControllersName")("theSlidersName").value > n - index) {
    transform.opacity = 100;
    } else {
    transform.opacity = 0;
    Now I can build up/down my stack with one slider.
    Hopefully this will be useful to someone in the future.
  • Daniel Waldron
    December 2, 2016 at 9:43 pm
    You could try this expression in your first layer, then every time you duplicate the layer, it will be slightly offset on the y axis:
    position+[0,(index-1)*4]
    (change the “4” to change how much the layers are offset)
    That obviously only solves a small part of your question. Ideally you could link the number of duplicated layers to a Slider Control, but I’m not sure how to do that.
    Alternatively, it seems like a combination of the Array script and the Rift Script may help also speed up the process.
  • Daniel Waldron
    December 2, 2016 at 10:11 pm
    Nice!
