Activity › Forums › Adobe After Effects › Animate c4d element in AE CC
  • Animate c4d element in AE CC
    Posted by Ari Grunzeweig on August 8, 2013 at 4:49 pm
    Hi folks,
    I have to animate a butterfly for a logo animation. Nothing too complicated. Wings are flat so the basic AE 3d functionality will do the trick. I need the body to have volume to it though. The body of the butterfly is simply a stretched out sphere.
    I figured I would try out the new integration with c4d. I created by body object in C4d and imported it into after effects. All good.
    The problem occurs when I try and move that c4d object to match my wings and then animated…
    I get a message ‘layer size must match comp and use default transform values’.
    Am I not understanding the workflow, or does all the animation need to occur in c4d?
    Thanks!!
    Ari
    Ari Grunzeweig replied 13 years, 1 month ago 2 Members · 3 Replies
  • Todd Kopriva
    August 8, 2013 at 6:49 pm
    Yes, you need to do the animation in Cinema 4D.
    After Effects team blog
  • Ari Grunzeweig
    August 8, 2013 at 6:57 pm
    Thats’s what I was afraid of! Sp after all these years, is there still no way to import and animate a 3d object into After Effects?
    Ari
  • Ari Grunzeweig
    August 8, 2013 at 7:24 pm
    I’m going to explore Element 3D from Video Copilot. I’ll keep you posted on the results.
    Ari
