Activity Forums Adobe After Effects animate between UPPERCASE and lowercase in one text layer with expression
  • animate between UPPERCASE and lowercase in one text layer with expression
    Posted by Trevor Morgan on November 19, 2021 at 7:43 pm
    Greetings folks!
    I’m trying to animate between UPPERCASE and lowercase in one text layer. Is there an expression that could do this with a checkbox control maybe?
    I’m trying to achieve a stop motion feel. Every 10 frames the text changes case. I created a base animation using the text animators (simple stuff like text sliding in/out). then pre-compd one with CAPS and another lowercase. In a comp above that, I animated between the two pre-comps with loop expressions and hold keyframes… thus switching between the two text cases.
    I could work this way, but if the client changes anything it becomes tedious.
    could you accomplish the same thing with expressions? Is there a better way?
    Any leads much appreciated!
    -Trevor
    Trevor Morgan replied 4 years, 10 months ago 2 Members · 3 Replies
