Activity Forums Adobe After Effects Expressions Animate based on duration
  • Animate based on duration
    Posted by Duane Walters on January 19, 2022 at 2:31 pm
    This has to be a terribly simple thing, but this is day two looking for anything of value and I’ve come up short.
    Manually: slider control and you set a keyframe of zero at the beginning and at the end set it to 24 (but this number changes).
    Expression: no matter what you set the end goal of that slider to, it always finishes at the end of the comp.
    Duane Walters replied 4 years, 7 months ago 1 Member · 1 Reply
  • Duane Walters
    January 19, 2022 at 3:42 pm
    I came up with this, I just feel like there’s probably a more simple way of doing this?
    linear(time, inPoint + 1, outPoint – 1, 1, effect(“Time”)(“Slider”));
