Activity Forums Maxon Cinema 4D Animate background sequence not working c4d r15
  • Animate background sequence not working c4d r15
    Posted by Mark Coory on September 30, 2013 at 8:39 pm
    I am working with a tracked scene from boujou in r15.
    And when i create my background object for my image it doesn’t scrub through live in the view port along with my tracked data.
    When scrubbing through the time line the background image doesn’t up date, however, when i stop and render the image on any frame the rendered image is updated and when i click off the rendered image it defaults back to frame 1.
    In the material editor the image plays if I hit the animate button so I know the frames are there and playing. Just not in the view port.
    I have done this a thousand times in r14 and below. I have also completed all c4d updates.
    I am running mac 10.8.4
    and am using tif sequences with the naming convention of name_name_01_00.tif, I have even tried different naming conventions and file types.
    thanks in advance.
    Dave Berry replied 9 years, 11 months ago 8 Members · 7 Replies
  • 7 Replies
  • Ronny Traufeller
    September 30, 2013 at 9:28 pm
    If done this also a lot of times, and i always let it calculate the Frames based in”exact frames”
    traufeller.de
  • Adam Trachtenberg
    September 30, 2013 at 9:53 pm
    In the material’s editor tab, check the “animate preview” box.
  • Miguel Peraza
    October 29, 2014 at 10:52 pm
    ADAM!!!!! The answer is so so simple. I was stuck on this problem for hours, and hit myself in the head when your suggestion finally got it to work. Thank you!
  • Emerson Ma
    November 24, 2014 at 2:52 am
    13 months after your post…Still
    Thank you Adam!
  • Paul Carder
    May 20, 2015 at 11:00 pm
    Hey Adam, you’ll be pleased to know that your answer helped me out over a year after you posted it.
    The ‘make work’ button is the animation preview checkbox. What a retarded default!….who would NOT want the footage to play!? Hmmmm.
    Anyway, many thanks! 🙂
  • Zorro Gamarnik
    August 3, 2015 at 11:31 am
    Thank you soso much !!!!!!!
  • Dave Berry
    August 31, 2016 at 8:20 pm
    Thanks a million for your response, been trying to figure this out for far too long. How did I miss that? lol
