Activity Forums Maxon Cinema 4D Animate Anchor Point of Array Object? (clip included)
  • Animate Anchor Point of Array Object? (clip included)
    Posted by Jason Connolly on December 2, 2005 at 1:32 pm
    Hello the COW!
    OK, I think is simple, but I can figure out how to do it. I have an array object of cubes (see clip here) that animate outward from the center point. How do I animate(or key frame) the anchor of the array object so the cubes animate out AND rotate on an axis at the same time? I want it to look like the cubes are the petals of a flower opening up. I can’t see anywhere that I can add a keyframe to the anchor point of the arrray. I should also add that I did ‘make editabe,’ so I can control rotation, but how do I animate the anchor point over time?
    Any feedback welcome!
    Jason
    Robyn Rhodes replied 16 years, 3 months ago 2 Members · 2 Replies
  • Jason Connolly
    December 2, 2005 at 5:51 pm
    By adding a null object between the array and the cube, the null object allows me control over the rotation of the array.
    –Jason
  • Robyn Rhodes
    June 15, 2010 at 4:13 pm
    Thanks Jason! One detail that’s important is the “Arrayed” object must be a child of the null with-in the Array, and you don’t need to touch the Null at all.
    I’m only half the thing I say I am, the other half are me.
