Activity Forums Maxon Cinema 4D Animate an elements alpha channel in C4D?
  • Animate an elements alpha channel in C4D?
    Posted by Dolphbean on October 30, 2007 at 7:51 pm
    I am pretty new to cinema 4d and I was wondering how you animate the alpha of individual elements like you can in after effects / flash etc.
    I want and object to alpha in then move.
    Is this possible in C4D.
    Adam Trachtenberg replied 18 years, 11 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    October 30, 2007 at 8:12 pm
    You would give the object a display tag and then animate the visibility parameter.
    If you don’t want the back side of your geometry to show through as it fades in/out, do the following:
    *give your object a compositing tag;
    *go the tag’s exclusion tab and drag your object into it;
    *click the transparency icon to the right of your object in the exclude box to activate it (straight arrow going through line).
  • Dolphbean
    October 30, 2007 at 9:49 pm
    Many thanks for your answer. It worked great!
    I have another question:
    How can i copy keyframes from the time line to place them again further down so as to reverse the animation?
    Many thanks for your help
  • Adam Trachtenberg
    October 31, 2007 at 3:11 am
    There are several ways to do it. The most direct is to drag/select you keyframes, then control/drag one of them to create/move your selection.
    Another way is to select them with the region select tool, copy (control + c), then drag another region and paste.
