Activity › Forums › Adobe After Effects › Animate a trace line around an object
  • Animate a trace line around an object
    Posted by Ashley Davis on August 24, 2016 at 11:10 am
    I have an aerial image of a skyline and I want to animate a line to trace around a particular building. What is the easiest way of doing this?
    John Cuevas replied 10 years, 1 month ago 2 Members · 1 Reply
  • John Cuevas
    August 24, 2016 at 12:51 pm
    Trace a mask around the buildings you want to animate then add the effect Generate > Stroke and set it’s Paint Style to “On Original Image”. Keyframe the end point.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
