Activity Forums Adobe After Effects Animate a layer behind a mask?
  • Animate a layer behind a mask?
    Posted by Andy Taplin on September 3, 2007 at 3:32 pm
    Hi
    I don’t know why I’m having trouble with this but it’s driving me crazy.
    I just want to animate a layer bahind a mask so that the layer moves but the mask stays put. So the mask is like a window through to the layer and the layer moves inside it.
    I’m using the pan behind tool to move the layer which is fine but as soon as I try and animate the position over time with a couple of keyframes the mask moves as well.
    Any ideas – this should be really easy!
    Andy Taplin replied 18 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andy Taplin
    September 3, 2007 at 3:43 pm
    OK I figured it out just after I posted.
    It looks like you set the mask path keyframes at the same time as the position keyframes and then they kind of cancel each other out!
    Still a little obscure for such an obvious thing to want to do…
  • Steve Roberts
    September 3, 2007 at 3:55 pm
    You can also mask a separate layer and use that as a track matte for the animated layer below.
  • Andy Taplin
    September 3, 2007 at 4:03 pm
    Thanks Steve
    So mask a solid layer and have it above the animated layer?
  • Steve Roberts
    September 3, 2007 at 6:55 pm
    Yep. Set the upper to be the track matte of the lower. Check the help for that.
  • Andy Taplin
    September 4, 2007 at 7:10 am
    Thanks Steve
  • Jeff Duncan
    December 12, 2007 at 6:11 pm
    Old thread, but you can also pre-compose your layer, keeping the mask on the composition, and then animate your layer inside the new composition. Hope that makes sense.
  • Andy Taplin
    December 13, 2007 at 9:47 am
    Thanks, nice to see the old threads still get read.
    More than one way to ‘skin a cat’ in AFX for sure.
