Activity Forums Apple Motion animate a jpeg on a b spline
  • animate a jpeg on a b spline
    Posted by Jason King2 on October 22, 2010 at 4:20 am
    Is it possible to take a b spline path you’ve created and attach a jpeg pict. to follow the path? I know you can do this with text, just wondering if it can be done with a picture.
    Jason King2 replied 15 years, 10 months ago 2 Members · 2 Replies
  • Zak Peric
    October 22, 2010 at 12:35 pm
    yes you can.
    Select the image then apply behavior/basic motion then motion path. in the path properties change from bezier to B-Spline. then double klick on your path to add the points and create a direction to which you want your shape to go. EASY…
    I hope this helps….
    https://www.embryo.me.uk
  • Jason King2
    October 22, 2010 at 4:56 pm
    Thanks, I figured there was a way. The manual is a little weak on explaining some things. I’m trying to dive a little deeper into the program and learn more.
