Activity Forums Adobe After Effects Animate 1500 objects?
  • Animate 1500 objects?
    Posted by Daniel Lap on February 9, 2013 at 4:34 pm
    I would like to animate 1500 copies of an icon.
    1. The 1500 icons should appear one by one in a grid formation.
    2. Each icon should be colored individually.
    Questions?
    1. Is this at all possible? Is Scripting the way to go?
    2. Should I create layers or can I somehow use a repeater and access instances programmatically?
    3. How do I keep the computer responsive with so many elements on the screen?
    Ridley Walker replied 13 years, 6 months ago 3 Members · 2 Replies
  • Vishesh Arora
    February 9, 2013 at 5:36 pm
    Daniel
    Have you created the icon in AE using Shape layers or is it a file that you have imported?
    Yes, It is possible to do so.
    If you have used shape layers then it would be possible to create this using repeater.
    If it is a file that you have imported then you can use expressions to animate the position, opacity and cycle the colors.
    You can also use Red Giant’s Echospace Plugin.
    It depends on the size of document, system specs and effects that you will use.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Ridley Walker
    February 10, 2013 at 1:05 am
    In addition to Vishesh’s suggestions, I suggest you look at Trapcode Form and Trapcode Particular.
    Form can easily produce a grid of icons each with a different color. Though how you are going to generate 1500 distinct colors may be more of an issue.
