Activity Forums Adobe After Effects Expressions “Animal behavior”
  • “Animal behavior”
    Posted by Joachim Sandvik on October 18, 2005 at 3:28 pm
    Hello!
    I have a image of an single spermcell with alpha channel, that i wish to multiply and swim around a bit, before it focuses on an object.. e.i an egg!!!!! and swims to that egg..
    The cell count should be around 75-100, and they all need to swim in diffrent dirctions before going for the egg.. Have tried with diffrent particle emitors, and masks, but no luck
    Any filters, tips etc on how to do this..
    Michael Szalapski replied 20 years, 11 months ago 5 Members · 5 Replies
  • Chris Smith
    October 18, 2005 at 3:42 pm
    I know this is an AE copout since I don’t know expressions in AE. Have you tried it in a 3D app? It’s easy there. In Maya create a particle cloud. Have each particle attract to a goal (the egg). Create a user slider for the goal weight. Let them swim around, then animate the goal weight slider up when you’re ready and they’ll head in.
    In C4D it’s even easier with the Xpresso tools.
    I’m sure there will be some genius responses here soon.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Joachim Sandvik
    October 18, 2005 at 3:52 pm
    Thanx… I sort of knew that a 3d app. would do the trick.
    was actually hoping for a AE or motion filter… Looks like a C4D job.
  • Antony Buonomo
    October 18, 2005 at 5:52 pm
    make it as a particle in Particle Playground or Particular, then animate the final guy independently
  • Matthew Reithmayr
    October 18, 2005 at 6:28 pm
    NOT speaking from experience…but trying to help…
    Couldn’t you use the sperm as a Custom Bubbles and guide the little fellas using a map?
    Matthew
  • Michael Szalapski
    October 18, 2005 at 8:50 pm
    In foam? You could, yes. That would quite possibly work.
    C4d is probably gonna be better though, ’cause you can do 3d camera moves.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
