Activity Forums Adobe After Effects Andrew Kramer’s 24P frame rate converter
  • Andrew Kramer’s 24P frame rate converter
    Posted by Ryan Santos on June 12, 2007 at 12:18 am
    Hi, I used Andrew Kramer’s frame rate converter to make 24P out of 30i footages. I rendered it out to make an uncompressed movie file. If I’m making a 24P DVD, should I send the finished movie straight to Adobe Encore? Or should I first bring it to Premiere Pro using the 24P preset project setting, make a final uncompressed movie, then have Encore import that finished movie? Right now, I have a project in my hard drive waiting for an answer. Thanks.
    Delete replied 19 years, 3 months ago 2 Members · 1 Reply
  • Delete
    June 12, 2007 at 3:12 pm
    You shouldn’t need to re-re-compress the thing in Premier. After effects is used for Onlining all the time. Just write out your final from After Effects.
