Activity Forums Adobe After Effects Andrew Kramer
  • Andrew Kramer
    Posted by Ryan Santos on March 14, 2007 at 4:15 am
    I used andrew’s method in converting my footages from 29.97 to 24 fps. I also deinterlaced them, using his method in his website. Now I’m going create a new project in Premiere and import the converted clips. The question is: when I start a new project, what will I choose in the load preset dialogue box, DV-24P or DV-NTSC? My guess is that I’ll use DV-24P since Andrew, in his tutorial, said that his technique make real 24fps… add his deinterlacing method and the clips should become 24P.
    Andrew Kramer replied 19 years, 5 months ago 3 Members · 3 Replies
  • Andrew Kramer
    March 14, 2007 at 10:07 am
    You would want to deinterlace and then retime. Good Luck,
    Andrew Kramer
    https://www.videocopilot.net
  • Tclark
    March 14, 2007 at 5:11 pm
    Why do you need to deinterlace? You tutorial shows that you are converting 60i to 24p. Isn’t this deinterlacing in that process already?
  • Andrew Kramer
    March 14, 2007 at 5:39 pm
    You’re right, I must have been out of it.
