Activity Forums Apple Final Cut Pro Legacy AND COMPRESSOR PROBLEM
  • AND COMPRESSOR PROBLEM
    Posted by Robyn Symon on October 30, 2006 at 3:35 pm
    I’m trying to export an 80 minute documentary using compressor. Settings
    DVD Best Quality 90 and then 120 minutes. MPEG2 and then Dolby. But it says Time Remaining Unknown for a long time leading me to think that it’s not doing anything. I’m trying to make a DVD. Thanks
    Chris Babbitt replied 19 years, 10 months ago 3 Members · 5 Replies
  • Chris Babbitt
    October 30, 2006 at 3:41 pm
    What version of Compressor are you using?
  • Chris Babbitt
  • Robyn Symon
    October 31, 2006 at 11:53 am
    Sorry the delay back to answer the question. The Compressor version is
    2.0.1. I’ve also tried to make a quicktime movie but when I try to encode (import the assets) it fails. The project is 79 minutes long. The final cut version is 5.0.2. Thanks.
  • Bill Lee
    October 31, 2006 at 4:44 pm
    So, do a quick test.
    Set in and out points on the sequence to encode about ten seconds worth. Export your short sequence as a reference movie and drag that into Compressor and encode that. Does that encode? If so, reset your In/Out points to a longer clip of that sequence and try again.
    How much rendering have you done? Try using the Render Manager
  • Chris Babbitt
    October 31, 2006 at 6:46 pm
    If you’re using anything earlier than the universal version, which I think is 2.2, don’t use “Best” quality. For a 79 minute piece, you should be fine with Single-pass VBR or even CBR. Two-pass VBR will take forever, and yield poor results.
