Activity › Forums › Adobe After Effects › Anchoring stills to moving images
  • Anchoring stills to moving images
    Posted by Sara Jean on October 3, 2007 at 6:18 pm
    Hi! I am trying to anchor a still image to a section of road on a moving image. The only problem is, that section of the road is all over the frame because of the way the footage was shot and the way the camera travels down it. Is there a way to anchor something to a color or pixel within an image so that no matter where that section of the image goes the still image will follow?
    Mike Clasby replied 18 years, 12 months ago 4 Members · 3 Replies
  • Steve Roberts
    October 3, 2007 at 7:07 pm
    AE has a motion tracking feature. Have you checked it out?
  • Kevin Camp
    October 3, 2007 at 7:08 pm
    yes, but you’ll need to use ae’s tracker to track that point on the footage, then apply the tracker data to the image (or a null and parent the image to the null)….
    a little confusing, check/search the tutorials for tracker or tracking and consult the help menu for how to use the tracker, if you have more specific questions or troubles with the tracker, just post them.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Mike Clasby
    October 3, 2007 at 7:41 pm
    Andrew does accessories for the Demonic here:
    Demon Face Warp
    https://library.creativecow.net/articles/kramer_andrew/Demon_Face_Warp.php
    Accessories = Sunglasses = Your still image
    It
