Activity › Forums › Adobe After Effects › Anchor points
  • Anchor points
    Posted by Neil Schollick on August 12, 2012 at 9:21 pm
    Hi Hoping this hasn’t been answered already, I really stuck on something that is probably really easy, can anyone tell me how to set the anchor point of a shape layer to the exact centre , such shapes as a star for example as i want to rotate it around its centre. Sorry if this answer to this question is obvious but a total begginer .
    Neil Schollick replied 14 years, 1 month ago 2 Members · 2 Replies
  • Robert Headrick
    August 12, 2012 at 10:05 pm
    Shape layers actually have two anchor points. The shape layer as a whole has an anchor point which by default centers to the comp, as you’ve noticed. But then within the shape layer, each “Group” has an anchor point that by default is at the visual center of that group. You can either animate using the specific transform properties of that group within the shape layer, or you can use the Pan Behind tool to manually move the anchor point for the entire shape layer to where you want it (the Pan Behind tool is the button to the right of the Camera tool at the top of the screen, and looks like a targeting window).
    For reference: https://forums.adobe.com/message/2041513
  • Neil Schollick
    August 13, 2012 at 8:15 pm
    Thanks Robert couldn’t see that for looking , it was driving me mad !! Thanks again
