Activity Forums Adobe Photoshop Anchor points on circle
  • Anchor points on circle
    Posted by Kurt Richardson on November 23, 2010 at 3:04 am
    Hi everyone, not sure if I’m missing something obvious here, but how do I put anchor points onto a circle once I have drawn it with the elliptical marquee? Should the circle be selected or de-selected? The “add anchor point” pen tool only allows me to outline a box but otherwise does nothing. Any help would be greatly appreciated!
    David Cabestany replied 15 years, 9 months ago 2 Members · 1 Reply
  • David Cabestany
    December 13, 2010 at 8:36 am
    you can only add anchor points to a path, when you use the elliptical marquee you’re actually doing nothing, just selecting a portion of your image, that selection can be modified by going to select>transform selection, but you can’t add anchors to it, those belong to bezier curves only.
