Activity Forums Adobe After Effects Anchor points for comps?
  • Anchor points for comps?
    Posted by William Gadea on November 1, 2005 at 10:29 pm
    I’m getting back to After Effects after being away from it for a while. I’m trying to edit an anchor point on a comp layer but I can’t find it when I select it. Other kinds of layers (like stills and movies,) on the other hand, do have the usual cross in the circle. Has something happened while I’ve been away… or am I missing something incredibly obvious?
    New York-based Editor-Compositor
    William Gadea replied 20 years, 9 months ago 4 Members · 5 Replies
  • Chris Smith
    November 2, 2005 at 1:16 am
    I assume you have one comp nested inside another comp. Open the attributes for the comp layer and there should be the anchor point parameter. adjust it and you should see an anchor move.
    Chris Smith
    https://www.sugarfilmproduction.com
  • William Gadea
    November 2, 2005 at 3:41 am
    Yes, one comp nested in another. I’m at home now working on AE 5.5 and I don’t have the same problem… I can see the anchor points on comps fine. Is there a setting or something I’m missing?
  • Miller
    November 2, 2005 at 10:11 am
    Perhaps Show Layer controls is “toggled off” under the view menu? This would affect all layers, not just comps, tho.
  • Digitalalchemy
    November 2, 2005 at 5:54 pm
    Enter the layer mode by double clicking the layer. There is pull down menu at the bottom of the layer window that controls what is shown – effects point, masks, or ancor point path…
    Craig Lawson
    Digital Alchemy
  • William Gadea
    November 2, 2005 at 6:49 pm
    Brilliant, thanks. I knew it was something like that.
