Activity Forums Adobe After Effects Anchor Point Problem? – Straight Path
  • Anchor Point Problem? – Straight Path
    Posted by Catrina Delos reyes on December 11, 2017 at 3:40 am
    Hello. So this thing’s bugging me ever since I noticed it. And I noticed it just recently. I’ve already made a few animations without problem. So I’m not really sure if this is something I need to be concerned about.
    I noticed that whenever I create a straight path (the red line), I can’t bring it to the center unless I manually drag it.
    As you can see, the anchor point was already on the center of line (I used ctrl+alt+home to bring the anchor point to the center on the path). But there was a small blue box located on its far left. And that’s what ae is centering whenever I click the center align and not the anchor point.
    I can only select the red line by selecting that blue box. But when I need to move it, I need to drag the anchor point and not the blue box.
    Changing the anchor point and position in both the shape and transform property doesn’t really do anything. It just moves everything including the the blue box.
    Why is it behaving like that? It’s really bothering me. It only happens on a straight path. Other paths/shapes work fine.
    I hope somebody can help. Thank you!
    Denis Verezhnokov replied 6 years, 12 months ago 4 Members · 3 Replies
  • Michael Szalapski
    December 15, 2017 at 3:57 pm
    You might have transform options inside your shape layer that you could tweak with that would help.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Praneet Tulshyan
    April 11, 2018 at 10:50 am
    anyone found a fix yet? have been facing the same issue. once i create a straight path using the pen tool, i just cannot select it directly in the composition. i can only select it by selecting it in the layer. it is highly annoying! even after bringing both the anchor points (of the layer and of the shape) manually to the centre, still selection is not happening!
  • Denis Verezhnokov
    August 30, 2019 at 7:17 am
    Hi, maybe I’m writing a little late, but I found a way to help you. Make the path of the line diagonal, and then return it back and then the anchor point itself will move to the line, and then press ctr + home to align the point to the middle.
