Activity Forums Adobe After Effects Expressions Anchor point positioning
  • Anchor point positioning
    Posted by Stanley Castello on April 13, 2022 at 12:12 pm
    Hi all!
    I am new on scripting so if you could help me I will appreciate it greatly.
    I have this function: It places two scale keyframes I need. My question is, how can I change the anchor point to middle/left before the scale keyframe is applied? I tried all kind of ways but nothing has worked 🙁
    function scaleUpLeft(){
    var comp = app.project.activeItem;
    if(comp === null){
    alert(‘Please open a comp’)
    return
    var keyTime = comp.time;
    var addTime = keyTime + 1.25;
    var myLayer = comp.selectedLayers;
    app.beginUndoGroup(“Scale up”);
    for(var i = 0; i < myLayer.length; i++){
    myLayer[i].property(“Transform”).property(“Scale”).setValueAtTime(keyTime,[0,100]);
    myLayer[i].property(“Transform”).property(“Scale”).setValueAtTime(addTime,[100,100]);
    app.endUndoGroup();
    Stanley Castello replied 4 years, 5 months ago 2 Members · 6 Replies
  • Dan Ebberts
    April 13, 2022 at 4:23 pm
    Something like this inside your loop, I think:
    var r = myLayer[i].sourceRectAtTime(0,true);
    var delta = [r.left, r.top + r.height/2];
    var ap = myLayer[i].property("Anchor Point").value;
    var pos = myLayer[i].property("Position").value;
    myLayer[i].property("Anchor Point").setValue([ap[0] + delta[0], ap[1] + delta[1]]);
    myLayer[i].property("Position").setValue([pos[0] + delta[0], pos[1] + delta[1]]);
  • Stanley Castello
    April 13, 2022 at 5:32 pm
    Something is telling me; you are a complete genius. That worked really well. Thank you very much.
  • Stanley Castello
    April 13, 2022 at 6:11 pm
    One more question, if I wanted the anchor point to be placed on top/middle would I just change the;
    var delta = [r.left, r.top + r.height/2]; <<–?
  • Dan Ebberts
    April 13, 2022 at 7:27 pm
    Yes:
    var delta = [r.left + r.width/2, r.top];
  • Dan Ebberts
    April 13, 2022 at 7:45 pm
    Oops, those are messed up. The first one should be:
    var delta = [r.left - ap[0] , r.top + r.height/2 - ap[1]];
    and the second one should be:
    var delta = [r.left + r.width/2 - ap[0] , r.top - ap[1]];
  • Stanley Castello
    April 14, 2022 at 1:01 am
    Works wonderfully! Thank you so much.
