Activity › Forums › Apple Final Cut Pro Legacy › Anchor point oddity…
  • Anchor point oddity…
    Posted by Michael Peele on November 28, 2005 at 8:35 pm
    Ok,
    I was trying to swing some clips into frame with a single corner anchored in the corner. So my 1st clip was going to swing in with its top left corner anchored in the top left corner, so I set my anchor at (-360,-240), key framed a rotation and everything was cool. For the next clip, it was to swing in from the top right. So I set my anchor at (360,-240) – the top right corner – right? Well apparently not. Even though the anchor line indicated that the video was at the top right, a corner of the video was still showing when the clip was rotated up. I am a little perplexed – shouldn’t 360,-240 be the top right, especially if -360,-240 is the top left? By the way, I am working in DV on a DV timeline and the corner that was showing was seen on the canvas ans the monitor, even without overscan engaged. Also, the clip had not been enlarged, cropped, or effected in any way prior to the anchor point setting. Easy to work around, but a little odd. Was this just a weirdness on my machine or is it a common problem/known issue?
    Mike Peele
    Kevin Monahan replied 20 years, 10 months ago 2 Members · 1 Reply
  • Kevin Monahan
    November 29, 2005 at 9:20 pm
    Hi Mike,
    Hard to really tell what the trouble is. How are you moving the anchor point to the corners? Do you use the distort tool. That’s the proper way to click and drag it around the screen. When a clip is scaled down, you get a “counterbalance” line that carries the layer number. That is NOT the anchor point, the point you are clicking and dragging on is.
    Your X, Y coordinates seem OK. As many do not know, the Y axis is “flipped” from the one you learned about in algebra class. You seem to have grasped that.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
