Activity Forums Adobe After Effects Anchor point issue
  • Anchor point issue
    Posted by Craig Ricker on January 24, 2013 at 1:04 am
    This has got to be so simple and every post i’ve read makes it sound so! But for the life of me it aint working.
    I have a picture layer in my composition. With 2 position keyframes. I simply want to move the anchor point to an edge so I can rotate the picture along that edge. I do not wish to move the picture from its current location.
    So I use the pan behind tool. BUT…..
    It does not select the anchor point but rather moves the position keyframes. I cannot get it to move the anchor point. What am I doing wrong?
    Craig Ricker replied 13 years, 7 months ago 3 Members · 4 Replies
  • Todd Kopriva
    January 24, 2013 at 1:31 am
    from After Effects Help:
    “Note: Moving an anchor point with the Pan Behind (Anchor Point) tool changes Position and Anchor Point values so that the layer remains where it was in the composition before you moved the anchor point. To change only the Anchor Point value, Alt-drag (Windows) or Option-drag (Mac OS) with the Pan Behind (Anchor Point) tool.”
    After Effects team blog
  • Craig Ricker
    January 24, 2013 at 2:26 am
    So I have a layer moving from the direct left off screen to the middle of the screen. horizontal movement
    I then desire to move the anchor point from the middle of that layer to its bottom right edge.
    I use the pan behind tool. But it moves only 1 of the position keyframes rather than both, and so even though the anchor point is now in the correct position the first position keyframe is now higher than the second position keyframe and so the layer moves into the center of the screen from a diagonal direction from the top left.
    How can I have it so that it adjusts all the position keyframes the same amount so that the position movements are varied?
  • Vishesh Arora
    January 24, 2013 at 8:23 am
    Craig
    I think you have not followed what Todd has suggested.
    Press Alt(+ Shift, if you want it exactly above the previous position) and the drag the Anchor point.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Craig Ricker
    January 24, 2013 at 10:20 pm
    You are correct of course, I was just curious about fixing it after I had made the mistake of first building the movement points.
    Or if I had a situation where I wished to move the anchor point mid way through an animation.
    I find if I use the Alt + Drag option it does indeed move just the anchor point, and then I have to readjust the position keyframes as a whole to move it back into position. Not too bad a solution after all.
    Many thanks everyone
