Activity › Forums › Adobe After Effects › anchor point
  • anchor point
    Posted by Heather Crank on June 18, 2007 at 10:46 pm
    Hello,
    I have an illustrator file that I brought into AE. I need this file to rotate in a precise circle, but when I do this the rotation isn’t even/centered. So my guess is that the anchor point is off. Is there a way to figure out the exact center and a way to position to anchor point there so it won’t move?
    THANK YOU!
    Heather
    Heather Crank replied 19 years, 3 months ago 3 Members · 4 Replies
  • Mark
    June 18, 2007 at 11:19 pm
    I would use the rulers and guides. If you bring guides to the edges of the circles, you can then use math and the rulers to figure out that point. There is probably an easier way, but I don’t know it…
    Mark
  • Heather Crank
    June 18, 2007 at 11:30 pm
    Thanks Mark, That’s what I thought.
    Heather
  • Darby Edelen
    June 18, 2007 at 11:57 pm
    You could try this expression on the anchor point:
    x = width / 2;
    y = height / 2;
    [x, y]
    This will put it in the exact center of the layer.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Heather Crank
    June 19, 2007 at 6:09 am
    Thanks Darby,
    I’ll give that a shot!
    Heather
