Activity Forums Apple Final Cut Pro Legacy Anamorphic? or not?
  • Anamorphic? or not?
    Posted by Tel Jaba on May 27, 2009 at 10:49 am
    Hey guys
    I just need to understand this once and for all
    when do you need to work and export as Anamorphic? and when do you export with a letterbox?
    I am working with 1920X1080 which will have to be SD for the final output, and I am not sure what setting to use!
    this will be shown on TV and distributed on DVDs,so it is only for TV
    should I work in a PAL DV sequence and have letterbox on the image (which looks pretty nice) or should I use another setting?
    I need your advice on this please
    Michael Gissing replied 17 years, 3 months ago 6 Members · 5 Replies
  • Walter Biscardi
    May 27, 2009 at 11:18 am
    [tel jaba] “when do you need to work and export as Anamorphic? and when do you export with a letterbox? “
    This wholly depends on the client’s request and/or the broadcast specification for the network we’re delivering to.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Nick Price
    May 27, 2009 at 1:44 pm
    HI,
    ask the network what the require, but 9 times out of 10 16:9 widescreen means full Height anamorphic. Letterbox is essentially 4:3 with the widescreen picture placed in the middle, with black bars on top and bottom, giving the appearance of widescreen. It isnt widescreen at all.
    It is the broadcasters job to transmit to the different types of TVs out there, so just ask them what they want.
    And most DVD players can tell (or be told) what type of tv they are connected to and change from 16:9 widescreen to letterbox depending on the TV.
    So if you have shot in 16:9 then edit and deliver in 16:9.
    Cheers
    nick
  • Jeremy Garchow
    May 27, 2009 at 4:00 pm
    [tel jaba] “Hey guys
    I just need to understand this once and for all “
    🙂 That’s a big under taking in the video world.
    You have good advice here. It usually comes down to, ask the broadcaster. Some can take the FHA (full height anamorphic) some can’t. It’s up to them.
    Jeremy
  • Michael Sacci
    May 27, 2009 at 5:10 pm
    One thing to keep in mind, if you edit and add graphics to a Lettebox sequence, there is no going back to 16:9 cleanly, you have to up-rez if you need it. If you edit 16:9 it is very easy to Letterbox when mastering if that is requested.
    Your DVD will want true 16:9 footage or else it will never look right on a widescreen TV.
    DVD players can convert 16:9 to Letterbox for 4:3 TVs very well on the fly.
    DVD player does not fit 4:3 Letterbox footage to a 16:9 TV at all, to get it to fit you have to use the TV’s zoom function and you are blowing up the image, not a pretty sight.
  • Michael Gissing
    May 28, 2009 at 1:16 am
    Never once in the PAL broadcast world have I been asked for letterbox. It throws a way a lot of resolution.
    Don’t use a DV sequence for your SD downconvert. That is a poor SD codec. Uncompressed or ProRes are best. Search the forum for ideas on how to end up with SD from HD as it has been covered here many times. My prefered workflow is to stay HD and then hardware downconvert at the end to SD.
