Activity Forums Apple Final Cut Pro Legacy Anamorphic stills
  • Anamorphic stills
    Posted by Kenny Powerass on December 22, 2005 at 10:20 pm
    I’m working on an anamorphic sequence. All my footage was shot 16:9, but I also have to include photos in it. I dropped some stills into it and FCP automatically stretched them to look like the footage. I’m monitoring everything on a 4:3 NTSC monitor so the footage looks stretched and people look skinnier then they are. In the viewer window everything looks naturally proportioned.
    My problem is that once the stills rendered they look fat and stretched to the sides of the viewer window and naturally proportioned in the 4:3 NTSC monitor. This is no good. What do I do to fix it so proportions are normal when it gets to a widescreen TV?
    I promised it would be done today because I saw no problems before the render. Now I’m in a hole.
    Kenny
    FCP 4.5
    Dual 2G G5
    OS 10.3.9
    Jerry Hofmann replied 20 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 23, 2005 at 2:49 pm
    Change the aspect ratio in the Motion Tab’s Distortion parameters to make them look right.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
