Activity › Forums › Apple Final Cut Pro Legacy › Anamorphic Sqeezing after Compression
  • Anamorphic Sqeezing after Compression
    Posted by Eric Klassen on August 18, 2005 at 5:44 pm
    I am working with a 16:9 anamorphic image, compressing it in compressor, and viewing it in DVDSP3 (This may be more of a SP3 question). When I view it in DVDSP3, the image is squeezed. Where is this happening and how can I fix?
    Ken Pugh replied 21 years, 1 month ago 3 Members · 2 Replies
  • Jeff Carpenter
    August 18, 2005 at 5:48 pm
    This is more of a DVDSP question. Ask it over in their room to get a more detailed answer.
    The basic idea, though, is that there are a couple of places you could check. The DVDSP monitor may be set for 4×3 and needs to be changed. Or perhaps the video track or the disc itself need to be set as an anamorphic DVD.
    I know how to find those things if I poke around for a little while, but I’m afraid I don’t know off the top of my head. At any rate, there’s nothing wrong with your video. ALL widescreen DVD video is squeezed when you take it in to DVDSP. That’s the correct way to do it. You just need to ask the DVDSP room how to stretch it properly.
  • Ken Pugh
    August 19, 2005 at 10:25 am
    Absolutely check in the DVDSP forum – but my understanding is that the stretching is done by the viewing screen (eg select widescreen on the TV remote). There is a way to embed a command to tell the TV to do this automatically (some cameras do this in the recording process) whether DVDSP can do this in post I don’t know.
    Ken.
