Anamorphic render settings for DVD Studio Pro
I wanted to make sure this methodology is correct. 3 questions:
For a 16×9, SD movie, to be played widescreen on DVD, (with maximum quality) the movie has to be rendered anamorphically then stretched back out with the DVDSP?
I found when using compressor to convert the 960×540 movie into a 16×9 mpeg 2, that it makes a 700 x 404 mp2. Seems like i’m loosing 46 pixels of resolution?
So if I take the final 960×540 square pixel movie, put it in a 720×480 comp, render it out, and set it up in DVDSP correctly. This will give me the highest resolution possible for a SD DVD?
I think i’ve got it but want a second opinion.
Thanks,Dustin
