Activity Forums Blackmagic Design Anamorphic PAL + SDI
  • Anamorphic PAL + SDI
    Posted by Carlos Lopez on June 25, 2005 at 7:53 am
    Hello, I have a problem capturing anamorphic footage. SDI + Decklink Extreme 5.0b4 + 10.4.1 + FCP5. All the settings capture and sequence are tagged to Anamorphic. But when i captured and open item properties doesn’t appear that it’s anamorhpic. And i have to do manually before drag to the timeline. Does exist any solution for it ??. Please i don’t want to tag every clip to anamorphic, with FCP 4.5 doesn’t happen. What i have to do ??
    Thank You
    Robroy replied 21 years, 2 months ago 2 Members · 1 Reply
  • Robroy
    June 28, 2005 at 12:25 pm
    I’m a Vegas user but for what it’s worth I have exactly the same problem. Capturing DB via SDI or using a J30 to downconvert to DV and capturing that no 16:9 flag is set in the captured file.
    It’s easy enough for me to fix when the files are on the T/L, RClick, Select Events to End, RClick again>Properties and change the AR of all of them.
    I’m certain there’s a way you should be able to do make the same global change in FCP, sorry I cannot help much with that one, maybe try a FCP forum.
