Activity Forums Apple Final Cut Pro Legacy Anamorphic issue
  • Anamorphic issue
    Posted by Paul Hartel on June 7, 2010 at 7:36 pm
    Gentlemen,
    This is the issue: Present project is (mostly) P2 card media. Footage was shot DVCPRO HD 720p60, 960×720. I’ve loads of quicktimes for this.
    Shooter also recorded one take to tape, and after capturing (somewhere else, don’t have a clue) exported out a quicktime at 720×480 – BUT,
    must have checked an anamorphic setting because the video is squeezed and barred top and bottom.
    Now, I can reexport and change the dimensions to correct the distortion, but I’m still left with the bars.
    Also, is that the best way to correct for this, or am I better off just importing into my project and “distorting the aspect ratio” and resizing to get the clip to match the others in the project?
    I don’t have time to have the shooter fix it at his end.
    Ph
    2 x 2.66 Dual MacPro, 7GBRam, 4T, FCP 6.02, MacOS 10.5.8
    Paul Hartel replied 16 years, 3 months ago 3 Members · 4 Replies
  • John Fishback
    June 7, 2010 at 8:42 pm
    Using distort (and possibly scaling) is probably the easiest way. Of course, this clip is probably SD and may not match your other HD clips. You might try doing the distort in Compressor and turn on Frame Controls and use the highest-quality setting for re-sizing. Compressor will do a better job of scaling than FCP. If the frame rates and/or codecs are different, then change that, too, in Compressor. For changing frame rates choose the highest-quality (in Frame Controls) for rate conversion.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Paul Hartel
    June 7, 2010 at 8:48 pm
    Thanks, John.
    I’ll give Compressor a try, too.
    Paul
  • Michael Sacci
    June 7, 2010 at 8:49 pm
    Sounds like it was shoot Letterboxed and not 16:9, though squeezed and barred is odd, do you mean stretched and barred? NOt much you can do about that, was not a capture setting.
    This is a major zoom to go up to HD, I would do it in Compressor and use Frame Control set to Best (optical flow) and do test with the
    Start with the preset Other Workflows>High Definition>DVCPRO HD 720p60
    Frame Control – On
    Resize Filter: Best
    Outout Fields: Progressive
    The rest you have to test to see what gives you the best image
    *** Geometry Tab***
    Source Inset (Cropping)
    Crop to: 16×9 1.78:1
    Make sure Dimensions are 960×720 Custom (16:9)
    Pixel AspectL DVCPRO HD…
    Good luck, this is probably not going to look pretty.
  • Paul Hartel
    June 7, 2010 at 9:40 pm
    Yes Michael,
    I probably do mean stretched and barred – I was thinking squeezed top to bottom, not side to side – an important semantical distinction.
    Thanks for the setting info. Soon to give it a try.
    Paul
