Activity Forums Adobe After Effects Anamorphic Graphics for 16:9 & 4:3 Letterbox
  • Anamorphic Graphics for 16:9 & 4:3 Letterbox
    Posted by Chris Magid on May 9, 2005 at 4:08 pm
    Looking for the highest quality way to create graphics for use in an 16×9 anamorphic SD finished product. This is heading to DVD so viewers have the choice of viewing it wide screen if they have a wide screen set or having the DVD letterbox the program for 4:3 viewing.
    Should I build it as 854×486 then squeeze to 720×486.
    OR
    Should I build it as a 720×486 using the Anamorphic (2:1) or NTSC Widescreen pixel ratio(1.2). If so which one?
    What would yield the cleanest results?
    Chris Magid
    RTVF
    Daniel replied 21 years, 3 months ago 2 Members · 1 Reply
  • Daniel
    May 22, 2005 at 10:41 am
    Hi Chris
    there are various ways you can approach this.
    One is to create 2 sets of graphics (16:9 and 4:3) wich the DVD author will then use in his DVD authoring programme (scenarist) to compile 2 versions a widescreen and a full frame one (4:3). If you go down this line remember to use in your 16:9 version the 4:3 safe areas.
    Start working on your graphics with the NTSC Widescreen settings, (photoshop has ready made templates) and than squeeze it down. When saving the graphics for the 4:3 version (if you used the 4:3 safe area in your 16:9 graphic)all you need to do is change the size of the canvas.
    For istance on a 16:9 PAL version you would work with 1024 x 576 than squeeze to 720 x576. For the 4:3 version of the same graphic, you would first squeeze the CANVAS to 768 x 576 than the IMAGE to 720 x 576.
    Also if you apply a guassian blur of about 0.3 to your final flat graphic you will help the graphic to stop shaking on the tv screen.
    Or
    You can do all your graphics/animations using a 16:9 setting and than the author will letterbox this in the authoring package.
    Hope this helps.
    Daniel
