Activity Forums Adobe Premiere Pro Anamorphic effect without squeeze
  • Anamorphic effect without squeeze
    Posted by Devin Mclaughlin on February 21, 2012 at 3:39 am
    For years I have been using FCP to edit. Once I moved over to Adobe, I noticed that I can’t quite get this same effect that I was able to pull of in FCP. In order to get a letter-boxed look and not have to crop my frame : I would make my FCP sequence anamorphic, which stretches out everything. Then I would place that stretched out sequence inside a non-anamorphic sequence and everything would balance back out, and I’d get my black bars without having to crop my frame.
    Here’s a low res screen shot:
    While I did notice a small loss in quality, I still prefer this over frame cropping.
    I can’t seem to find a way to make Adobe Premiere do the same thing though!
    Devin Mclaughlin replied 14 years, 6 months ago 3 Members · 4 Replies
  • Jeff Pulera
    February 21, 2012 at 2:35 pm
    Hi Devin,
    Please share the following: Source video format and project preset used, and what size do you want the final output to be? Too much guesswork, we don’t know what you are working with. Are you starting with 16:9 and want it to look like 2:35 cinema or what?
    Jeff Pulera
    Safe Harbor Computers
  • Devin Mclaughlin
    February 21, 2012 at 10:48 pm
    Source video : 16:9 1280×720. I’m not sure about the cinema aspect ratio that I got from doing this effect in FCP, basically I was just happy to get a letterboxed look without cropping my frame and I’m trying to duplicate this in Adobe Premiere.
  • John-michael Seng-wheeler
    February 22, 2012 at 12:10 am
    If you really want to make your video look wider without cropping then the easiest would be to nest your finished sequence in another sequence, go to the motion settings of the nested sequence, unlock the aspect ratio lock and decrease the vertical percentage.
    This will squish the video exactly as you were doing in FCP, though without a generation loss from rendering.
  • Devin Mclaughlin
    February 22, 2012 at 8:57 am
    Thank you! this seems to do the trick without making the frame looked squished
