Activity Forums Adobe After Effects “Anamorphic” effect with drone footage
  • “Anamorphic” effect with drone footage
    Posted by Steve Kunz on April 10, 2015 at 2:49 pm
    I recently shot some drone footage with a camera had a camera with a fish-eye lens. I know that I can remove the fish-eye effect in after effects by using the “optics compensation” effect.
    However, when I use this effect, it stretches out the footage and the edges of the image are cut off. Is there a way to stretch out this wide angle footage without losing the edges of the image? I’m fine with changing the aspect ratio to give it an “anamorphic” look. I just don’t know how.
    Any suggestions would be wonderful!
    Derek Boettcher replied 11 years, 5 months ago 2 Members · 2 Replies
  • Steve Kunz
    April 10, 2015 at 3:51 pm
    That is definitely possible…but it would be pretty costly. We would have to purchase a new camera and we don’t have budget for that right now.
    But I agree, it definitely would have been preferable to shoot with a normal lens.
  • Derek Boettcher
    April 10, 2015 at 3:54 pm
    You can adjust the aspect ration by going to your project panel, right clicking your comp, and then choosing comp settings. There you can unlink your pixel counts, change them to your liking, or go a step further and just type in a new ratio. Select accept when done, and it will change. If you have other comps or precomps, you will need to repeat the process to get the ratio for all of them.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
