Activity Forums Avid Media Composer Anamorphic conversion to 16×9
  • Anamorphic conversion to 16×9
    Posted by John Reis on October 8, 2006 at 2:22 am
    I have an anamorphic source that I am going to need to output at 16×9 letterbox. Whats the best way to do that in avid? Do I change the vertical size to 75% in 3dPIP? And then do I apply the 1.85 film mask crop? Do I nest the 3D PIP?
    Also I need to apply another format 14x(10?), a ratio I have not worked wirh, is that PAL?
    Sebastian Riezler replied 19 years, 6 months ago 4 Members · 3 Replies
  • Michael Phillips
    October 8, 2006 at 11:56 am
    You go to the reformat tab of the effects palette and drop a preset 16:9 letterbox on the top track.
    Michael
    anything 24fps
  • Bouke Vahl
    October 12, 2006 at 8:59 am
    Resize 75 % does the trick. I normally crop off a few pixels bottom and top (either crop or a static title with black bars bottom and top)
    14:9 is a compromise that BBC uses to be able to reformat almost anything. Check BBC specs for more details, and ask the client for more details as it can mean letterbox or anamorph…
    (if it is anamorph you have to set your titles away from the left/right edge as there will be a slight center cut)
    Bouke
  • Sebastian Riezler
    October 18, 2006 at 2:28 pm
    that’s what i wanted to know for a long time!
    if i just scale the image down in height to 75% then i always see a litte ‘step’ in the middle of the picture at the top or bottom (i know its because of the interlaced lines of a frame). so i have to crop it for 2 pixels (one is not enough as i experienced) top and bottom. this kills some more lines of my imaget and this results in a not 100% true 16:9 letterbox format.
    do i really have to downscale it by 75%, because i think, what i see is an underscan image which shows more than the viewers will ever see. so shouldn’t it be enough to scale it down about 85% (i don’t know if this is the correct percentage)
    would be cool if someone ever handeled this ‘problem’
    rock on
    Riot
