Activity › Forums › Apple Final Cut Pro Legacy › anamorphic clips not being imported as anamorphic
  • anamorphic clips not being imported as anamorphic
    Posted by Adam Boden on September 15, 2008 at 9:20 pm
    i’m digitizing my footage in offline rt ntsc anamorphic, but when i go to import the clips into my fcp project, final cut doesn’t recognize the anamorphic flag, and the media comes in squished. i have to manually check the anamorphic box for each clip, which on its own wouldn’t be that bad, but multiple editors are working on this project, so if one of them were to import this media and not recognize that it’s not coming in anamorphic, things would have to be re-edited.
    thanks in advance!
    -Boden
    James Palugod replied 17 years, 11 months ago 3 Members · 3 Replies
  • Rafael Amador
    September 16, 2008 at 3:39 am
    FC normally only recognize Anamorphic on capturing, and this because you check the Anamorphic window. Even when you export something Anamorphic from FC and you re-import it, FC doesn’t knows that is Anamorphic unless you check it manually.
    Rafael
    http://www.nagavideo.com
  • Adam Boden
    September 16, 2008 at 6:16 pm
    thanks for the answer rafael. looks like we’re stuck doing it manually!
    an “import as” feature would help tremendously. anyone work at apple and want to suggest this? 😀
  • James Palugod
    October 22, 2008 at 3:20 pm
    had the same issue. did a little poking around. you need to go to audio/video settings, capture tab, select the preset you normally use for the media you import, duplicate it, edit it, and check off anamorphic.
    Hope that helps.
