Activity Forums Apple Final Cut Pro Legacy Anamorphic 720x 480 NTSC DV
  • Anamorphic 720x 480 NTSC DV
    Posted by Jimr on May 13, 2005 at 5:55 pm
    Is there any easy way to go to 4:3 Full Frame Seq (not Letterboxed) From a Anamorphic DV Seq
    Nesting to a 4:3 Seq automatically makes it Letterboxed
    Do I have to Blowup from there And Pan & Scan
    Thanx,
    JimR013
    Jimr replied 21 years, 4 months ago 2 Members · 2 Replies
  • John Pale
    May 13, 2005 at 6:40 pm
    You dont have to blow it up. The image is the same height as in 4:3, but it is wider. You just have to stretch it out to its full width (yes, the sides will be cut off) in the motion tab or use the wireframes in the canvas. Do it to one clip, then use paste attributes to apply to all. Then you need to choose whether to keep the shots centered, cutting off the sides in a 4:3 frame or do a pan and scan. If you did any DVE moves, you will have to redo them for the different frame size.
  • Jimr
    May 14, 2005 at 12:05 am
    thanx for the reply back John, I’ll try that.
    Do I stretch it out in the anamorphic Seq.,
    And is there an exact Amount to stretch it out to?
