Activity Forums Apple Final Cut Pro Legacy Anamorphic 16:9 to 4:3 with black bars?
  • Anamorphic 16:9 to 4:3 with black bars?
    Posted by Thomas on October 5, 2006 at 4:29 am
    How do you guys normally transfer Anamorphic 16:9 to 4:3 with black bars?
    I usually copy and paste my Anamorphic 16:9 clips from one timeline to another timeline with 4:3 DV settings and it automatically squishes it and adds the default black bars.
    The only problem is that I would have to render it and then export it and it takes way too long.
    I also notice that whenever I do this, the image is a little bit more squished than normal.
    There has to be another way.
    Ben Holmes replied 19 years, 11 months ago 3 Members · 2 Replies
  • Andy Mees
    October 5, 2006 at 6:09 am
    an easier way would be to simply drag and drop your whole sequnece into the 4:3 timeline, rather than copying clip by clip.
  • Ben Holmes
    October 6, 2006 at 2:00 am
    Export the entire timeline as a QT clip, sound and vision.
    Re-import the clip, and drop it into a 4:3 timeline, so it’s letterboxed. Of course, you’ll have to render it for a print to tape, although it’ll play in RT off the timeline.
    You may find in DV that you have some interlacing visible (or even a purple line caused by DV VITC) at the top and bottom of frame. You may get a cleaner letterboxed image by cropping the top and bottom by one line. You image will not be squash incorrectly by this method – if it looks wrong it’s your monitor.
    The advantage of this method is that the render you do will be much quicker – and it gives you a handy backup of the timeline.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations. FCP systems just used on Sky Sports coverage of the Ryder Cup – live from the K Club.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
