Activity › Forums › Apple Final Cut Pro Legacy › Anamorphic 16:9 sequence issue
  • Anamorphic 16:9 sequence issue
    Posted by Abs Visuals on June 13, 2005 at 7:42 pm
    Simple issue, having captured footage with FCPHD 4.5, I have began to lay down the edit on the timeline. The sequence needs a proxy render before playing. The captured rushes are anamorphic 16:9 but the sequence shouldn’t be anamorphic 16:9. Why does the clips need rendering?
    Aj Epstein replied 21 years, 3 months ago 3 Members · 3 Replies
  • Jimr
    June 13, 2005 at 8:16 pm
    If you capture in NTSC DV Anamorphic then your SEQ. must be NTSC DV Anamorphic also in order not to have to Render.
    If U want to finish in 4×3, then first edit in Anamorphic then when edit is complete Drag to a DV non anamorphic SeQ. Then Render.
    If U are Editing in Anamorphic then make sure your Captured Clips are Checked in Browser under Anamorphic
    otherwise it will need Render, thinking they are 4×3 Clips.
  • Aj Epstein
    June 13, 2005 at 8:53 pm
    my sequence settings are properly set for anamorphic.
    any idea’s what’s causing these vertical bars?
  • Aj Epstein
    June 13, 2005 at 9:09 pm
    oops, replied to thre wrong post.
