Activity Forums AJA Video Systems Analog video output format with Kona 2
  • Analog video output format with Kona 2
    Posted by Pierre Tremblay on January 29, 2007 at 3:55 pm
    What is the correct setup for the component analog video output in the
    Kona 2 control panel? Component SMPTE/EBU N10 or Component BETA?
    What is the difference? I’m monitoring with a Sony PVM-14L2 using
    component. My material is for North American broadcast or DVD. I’m
    presently using SMPTE/EBU N10.
    Pierre Tremblay
    Tony Markward replied 19 years, 7 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    January 29, 2007 at 4:42 pm
    Are you laying off to Beta at all? If so monitor Beta, if not monitor SMPTE/EBU N10. Make sure your monitor is set up for the same as well.
    Jeremy
  • Pierre Tremblay
    January 29, 2007 at 5:04 pm
    I rarely finish on BETA, always digital. Actually, a post house does
    the final broadcast corrections for me since I don’t own scopes or
    a BETA recorder, only a player. Is the difference in the 7.5 setup?
    Pierre
  • Jeremy Garchow
    January 29, 2007 at 5:31 pm
    No, the setup should be added to all analog formats, not just Beta. Beta actually has a SLIGHTLY different color space. You will notice some luminance changes if you switch back and forth between SMPTE and Beta as well.
    Jeremy
  • Tony Markward
    February 6, 2007 at 8:58 pm
    Does the Beta colorspace apply to Digibeta as well? Or just analog Betacam?
