Activity Forums Adobe Audition Analog Timecode
  • Analog Timecode
    Posted by Ryan Risley on May 23, 2007 at 8:58 pm
    Hi – please forgive me in advance if this is a stupid question.
    I have an editing project that needs the audio sent to a big audio house for ADR & VO’s. I edit (at work) in Premiere and use Audition to do a lot of audio adjustments. I have been asked to send an analog timecode on one of my tracks, so that their Pro Tools system will track and follow everything.
    I have an old school Layla 20 with BOB that I use for my sound card. Along with the 8 in/8 out 1/4″ connections, it has midi (in,out,thru) word clock (in,out) and spdif (in,out).
    I also have an old MOTU midi timepiece II which I just got (to use as a midi patch bay) but it has no manual. It has smpte (1/4″ jack in/out) and midi (duh) on it. MOTU has absolutely no manuals for there old products 🙁 but I thought I read somewhere it can convert midi to smpte and vise versa
    Is it possible to run a (smpte) midi siginal out of my layla and into the MOTU – which can send a signal out through the 1/4″ smpte connection, and then recorded by one of my 1/4″ connections on my Layla – as an audio track in Audition?
    If not – what would you suggest in order to record an analog timecode? I saw an old product by midiman called the mac syncman which mentioned converting midi to smpte as well as being able to generate a smpte stripe.
    I have no idea about any of this 🙁
    Many thanks for any help or advice!
    Ray Drueke replied 16 years, 4 months ago 3 Members · 3 Replies
  • Ryan Risley
    May 25, 2007 at 1:21 pm
    Anyone? Bueller?
    Maybe analog timecode is as much a mystery to everyone in this forum as it is to me 🙁
  • Bouke Vahl
    June 28, 2007 at 9:37 pm
    analog timecode is just a stupid audio signal.
    If you can create it digital, fine. Just use it.
    If you have a hardware box, let it run and record it…
    If it sounds ugly, it’s probably allright 🙂
    (no idea why anyone wants it, if you give them a file with a start/end beep and the proper timebase, any sound workstation can link to it… Mind you, i’m a TC GEEK and develop a lot of TC products, but this is not a biggy….)
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Ray Drueke
    April 22, 2010 at 8:19 pm
    Bouke,
    Boy this is an old thread but its pertinent to what I’d like to do. I also just found and downloaded the RTltcGenerator from your web site.
    I am starting to do 2 and 3 camera shoots of live music performances and I try to pay special attention to the audio by recording up to 16 channels of audio from the stage mics etc via mic splitters to a 24 trk hard disk recorder. So far I’ve been syncing all this by matching up the audio tracks from the hard disk recorder and the cams as best I can. I record video with miniDV tapes so I also have to load those into the video editor as well.
    I currently use Premiere (Pro and Elements) and Audition as well as ProTools when necessary.
    Somewhere I read that most video editors can recognize LTC in an audio track so I’m thinking I could get a LTC or TOD track onto each video cam and onto a track on the hard disk recorder and then use that to sync in post. I thought about using remote procedure calls to get 3 (or more) copies started, each on a laptop connected to a wireless LAN and also record the video to each laptop via HDsplit or something similar.
    Would all this work? Is it possible that your software could become a callable sub routine or…
    Does anyone know for sure that Premiere Pro (2.0) can recognize LTC or TOD in an audio track/
    Other ideas or am I chasing a dead end?
    Ray.
