Activity › Forums › Canon Cameras › Analog line in on the Canon GL 1
  • Analog line in on the Canon GL 1
    Posted by Paulo Mateus on August 9, 2006 at 1:10 pm
    I’m trying to record some analog footage into a Mini DV Tape with my Canon GL1. I followed the steps as are mentioned on the instructions manual. I connnected the S-Video to the camera, in the VCR mode I press Rec Pause button and then when I released the pause bottom, the camera doesn’t record and the following message appears “Check the DV input”.
    What I’m doing wrong?
    Paulo
    Don Greening replied 20 years, 1 month ago 2 Members · 1 Reply
  • Don Greening
    August 10, 2006 at 5:43 am
    This is the procedure for recording analog to Mini-DV with a GL2. Check the owner’s manual for your GL1 but it’s probably similar:
    Go to VCR setup > AV-DV Out in the camera menu. Set this to OFF. Now the signal should be sent through to the RCA/S-Video conections instead of the DV/Firewire connection.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
