Activity Forums Media 100 Analog inputs broken
  • Wickham Strub
    July 8, 2009 at 9:34 pm
    That’s exactly who I was thinking of when I wrote that.
    See my new post re: 13.0.4. It’s UP!
  • Marc Morel
    July 9, 2009 at 1:40 pm
    Hi All,
    13.0.4 installed like a charm. Analog inputs back to normal. Thanks Matt, Wick and Floh.
    One small oddity though; when digitizing from Betacam SP via component, the image is fine in the source window in the app and the digitized file is fine but it looks like something is out of sync on my NTSC monitor. My interviewees look like smurfs (they’re blue) and there is a solid black line running top to bottom of the monitor towards the left side (Not drifting though). I’ve checked my Genlock settings, it’s set to Ref. In. I’ve put the ref signal to the scopes and it looks fine. The digitized file even plays out OK in the NTSC monitor. Any idea what I’m missing here?
    Marc
    MacPro 2×3 GHz Intel, 5 GB ram, Mac OS 10.5.6, Media100 v.13.0.4, QT v. 7.6, Aja Kona LHe 6.0.3 NDD
  • Paul Crowe
    July 10, 2009 at 6:41 am
    > One ‘small oddity though… my interviewees look like smurfs…< Ha... that's funny. Marc you are the master of the understatement. Some off my clients would get pretty upset if they came out looking like smurfs. Cheers Paul
  • Floh Peters
    July 10, 2009 at 6:48 am
    It seems like the analog input but is only partially solved. While the clips you capture are okay, you get a somewhat non-standard video out during capture. Seems like adding support for the Kona LHi opened a can of worms of problems…
  • Marc Morel
    July 10, 2009 at 1:08 pm
    Thanks for posting back Floh. Since it only marginally affects functionality, I guess we’ll just wait for 13.0.5 or whatever v.# is next.
    Marc
Page 2 of 2
