Activity Forums Blackmagic Design analog input interference
  • analog input interference
    Posted by Paul Provost on February 18, 2006 at 4:55 am
    I know this has been adressed many times, but we have not been able to resolve the problem.
    we have 3 decklink extreme systems in dual G5 systems, currently all the latest software & operating systems (FCP studio etc)
    ALL 3 systems cannot be used with the analog composite inputs due to “interference” “scrolling vertical bars” etc.
    we used to not have the problem at all, but somewhere along the line in the last year, due to some update, the problem apeared on all the systems
    All the G5s have NVidia cards which are not supposed to cause the “shielding problem”
    as it is the only way we can get a clean analog input is to route the signal through our digibeta, and capture sdi from the digibeta
    this is really lame since the same systems did not used to have the problem
    the 3 cards were purchased at different times over a couple of years so its a persistent problem
    one odd thing we noticed is on one system, we did not have enough sync outputs from our generator, so we used one of the bars outputs to sync the decklink card – which should be fine, and does work fine when the system is in sdi. but when the system is set to analog input, you can actually see the bars faintly “leaking” through into picture. I think this might be where the problem lies. is it possible that the sync inputs of the cards are not properly shielded or something?
    moving cards around, putting other cards between the deckling and the AGP card have not solved anything.
    I can’t be the only one having this problem
    Paul Provost replied 20 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Paul Provost
    February 19, 2006 at 6:40 pm
    btw this is an input problem
    the interference is recorded in to the captures
  • Paul Provost
    February 21, 2006 at 6:03 am
    I posted politely and sent email to US support and was flamed
    will forward you reply if you like
  • Yves De muyter
    February 21, 2006 at 10:36 am
    Shouldn’t you put “BLACK” into the reference input of the decklink?
    I see all sort of weird things in a lot of machines if I put colorbars as reference-in…
    -Yves
  • Mike Johnton
    February 21, 2006 at 11:47 am
    A typical novice mistake is to use something other than BLACK as a blackburst into a sync input. These inputs are designed for blackburst input and most do not work well if you put in something other than blackburst.
    Since you speculated that color bars might be a problem, did you simply just try using blackburst?
    -Mike
  • Paul Provost
    February 21, 2006 at 3:35 pm
    yes if you read my post, you will see that bars was tried on only one of the systems
    the results were posted as a diagnostic note
    and it does provide sync when using the system in sdi
    it is otherwise irrelavent to the problem
    all the systems are having the problem when receiving a true sync feed from the grass valley generator
    and again these systems did not have the problem previously – the only thing that has changed in the facility is software updates
  • Shane Chadder
    February 21, 2006 at 10:55 pm
    Paul
    Ground loops and noisy/dirty power can cause this sort of thing to. You might want to try one computer with monitor by itself (no sync gen) with one analog vtr feeding the BM card and no other connections. The computer/monitor/vtr should be all powered from the same power bar and no UPS. If it goes away gradually restore your other power and video connections to try and identify the source of the problem.
    Shane
  • Paul Provost
    February 22, 2006 at 2:37 am
    wow, an actual constructive reply
    thank you shane!
    I suppose power in our whole building could have gone bad, thus affecting all systems.
    all systems do have UPS, but I guess that’s not a power conditioner…
    I tried something similar a while back, but I think I still had reference feeding the card.
    I will try and post results
