Activity › Forums › Adobe Premiere Pro › Analog Capture with Matrox MXO Mini: close but no cigar
  • Analog Capture with Matrox MXO Mini: close but no cigar
    Posted by Mark Hubert on January 6, 2013 at 3:13 pm
    Hi, I’m hoping some wise user can help me find the missing link.
    I’m trying to digitize VHS via Capture using Matrox MXO2 Mini MAX (3.2.0.0024) into my MacPro (10.7.5) running CS6
    I’m getting video and audio signal to the Capture window, but when I hit record it looks like it’s doing it’s thing as “Stopped” changes to “Capturing Name.mov. Hit Esc to stop recording. Capture Duration: 00:00:00;00”
    The capture duration never increments and no file gets recorded. Hitting the Esc doesn’t do anything either.
    Capture Settings: Capture Format – Matrox Recorder
    Video Capture Settins – Video Format: 720p 59.94 10-bit (Codec = DVCPRO 720 60 (choosed to match other footage))
    Device Control – None.
    Capture Location is to my internal RAID (experimented with choosing my OS drive)
    Premiere Prefs:
    Capture – Abort on Dropped frames is OFF, Report dropped is ON, Generate batch only on unsuccessful is ON, Use Device timecode OFF
    Since I’m getting AV to the control window, I feel like I’m close and just missing something….
    Any help would be much appreciated.
    Mark
    Mark Hubert replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
